传感器给办公室带来光亮
消耗积分:0 | 格式:rar | 大小:0.13 MB | 2017-07-05
分享资料个
  传感器给办公室带来光亮
  工业照明空间是用来定义特定任务的光类型和颜色的场所。因此,无论是基于对象的还是基于光子的传感器,都能确保在给定情况下的照明性能和一致性。这些环境包括环境照明和作为机器视觉系统的一部分嵌入在机器中的高功率照明。这些系统中的传感器通常不仅提供照明控制的去/不去决定,而且还提供与光相关的值度量数据。此信息用于监测和控制照明使用自定义混合的光模式。在更高级的应用,这些传感器可以是一个控制回路包括DMX基光测序和操纵部分(上、下、调光,等)
  为什么基于传感器控制?
  工业照明市场不同于住宅市场,工业照明的照明解决方案大多难以控制或难以控制。最实用的照明是左在车库、楼梯间、地下室的所有时间,和存储区。由于它们的使用是随机的和不定期的,雇佣员工手动控制灯光是不经济的。这些区域也很大,所以历史上的本地化自动化是不实用的,以支持照明控制功能。
  Other types of industrial lighting are difficult to control due to location. In machine lighting, movable lighting (either standalone or tethered to equipment), and tall facility lighting, manual control is a challenge. The issue with automation is the speed, reliability, and the ability to discriminate between situations, which, if mastered, can enable active control rather than leaving the lights on at all times.
  A connected “smart” sensor approach addresses a number of these issues by using the proper combination of sensors and sensor types, and high-speed actuators as well as wired, optical, and wireless communication to identify the context of an industrial situation and determine the best course of action based on a decision matrix. This capability is possible on either a remote or local basis due to the capabilities of the embedded processors and the speeds of the internal state machines for sensor processing.
评论(0)
发评论
下载排行榜
