智能照明进入工作场所
照明市场的变化,从简单的手动控制开关到智能自动化环境,带来了一个根本性的设计转向照明工业控制。传感器和分布式微控制器通过有线或无线网络进行综合使用是当前改造和新设计的标准。Digi-Key使这些系统的开发由放养专业微控制器和传感器的照明控制市场。这些包括板级和基于FPGA的解决方案的完整的硬件和软件开发环境。
什么是照明自动化?
大多数照明自动化的目标是工业综合体和高层办公楼。主要控制是设置灯的开/关状态。最初控制是手动的-当你进入一个房间,你会打开灯,然后关上你离开时,除了在一些关键领域的灯总是出于安全目的。20世纪80年代早期的主要进展是运动传感器,它通过使用简单的运动检测器来检测开/关功能到“免提”功能,以判断是否有人进入房间,在这种情况下,它会打开灯。这种简单的技术现在已经被过滤掉了,是在轻交通地区居住建筑的一种安装/建造“规范”的要求。
Lighting automation now has a number of functions to manage since there are multiple types of lighting (incandescent, CFL, LED, OLED)。 The management functions include status, state (ON, OFF, dim), lifecycle for replacement and repair, power management for the room, sensor feedback, power adjustment (blackout, brownout, load shedding , peak usage control), integration with HVAC, and integration with event and security control. In order to interface with these automation systems, the lighting needs intelligence – distributed information from embedded controllers and sensors that communicate to a centralized management hub through both wired and wireless networks. The key for lighting control in modern automation systems is passive/non-invasive monitoring and active management of the lighting system in the context of the overall energy use and light delivery plan.
