SSL应用的降压转换器
Buck变换器是高效率、自我调节的电源。当正确理解和设计时,他们可以提供低损耗电流源来驱动LED阵列。
Buck变换器是最常用、最常用的开关电源拓扑之一。这种拓扑也被称为下变频器,因为它的主要特点是:输出电压总是低于输入电压。一个降压转换器可以非常有效(易于高达95%的ICS)和自我调节,这使得它的任务,如转换12 V到24 V典型的电池电压在笔记本电脑到处理器所需的几个电压非常有用。这种拓扑不仅可以用来转换电压,而且还可以作为电流源,这取决于控制方法。
本文讨论了一种Buck变换器的一般原理和注意事项,特别是在带谷导的边界导模中用于降压型二极管的降压变换器。它包括损失部分和关键部件计算。本文可用于设计时的几个NXP公司的LED驱动芯片的Buck变换器,如ssl1523,ssl1623,ssl2101,ssl2102,和UBA 3070。dimmability和电源dimmability不讨论,这是每一个具体的解。
Theory of operation shows how voltages and currents flow during one converter cycle. It also gives a short overview of the trade-off between CCM and BCM/DCM modes.
Key components design procedure gives information on how to design key components, such as the inductor value. It describes the resulting calculation of peak current when BCM, with valley detection, is used.
Power calculations gives designers an insight into the loss mechanisms in the converter, and how their choices affect efficiency
Current tolerance and stability discusses both issues.
