调光LED与传统TRIAC调光器
TRIAC调光器设计用于电阻性负载如白炽灯或卤素灯,有一个显着的安装基础,在美国和世界各地的。不幸的是,这些相位控制调光器是不容易兼容的LED由于LED不显示为阻性负载。因此,基于LED的解决方案,使用传统的LED驱动器将无法按预期与可控硅调光器壁。
The TRIAC is a semiconductor triode that features two terminals and a gate. It may help to think of the TRIAC as two silicon controlled rectifiers (SCRs), which are a type of thyristor, placed back to back. A typical SCR has four layers of alternating P-type and N-type semiconductor material.
An SCR turns off when no current is flowing through it, and it can be switched on when a current is applied to its gate. An SCR conducts current in a single direction, but a TRIAC can conduct current in either direction, which is why a TRIAC looks like two SCRs.
