了解蓄电池的能量收集规范
消耗积分:0 | 格式:rar | 大小:0.09 MB | 2017-08-17
分享资料个
  了解蓄电池的能量收集规范
  能量收集是一个包含许多技术的不同领域。蓄电池技术同样多样化,有多种电池类型用于存储能量,因为有从环境中提取能量的机制。在选择电池储存能量的方法时,必须考虑各种可能的条件,从波动的能量输入水平到潜在的对能量的需求。幸运的是,各种各样的电池类型和性能可用于存储与所需的能源生产和负载配置文件,本文将探讨一些主要的选择。
  电池的基本化学成分是铅酸蓄电池或锂离子电池。在每一个基本化学领域都有不断发展的技术,导致新材料改进了基本的电极结构。因此,对于能量收集系统的设计者来说,充分理解电池规格是很重要的,以便在当前可用的产品中做出正确的选择。
  Today, there are many types of secondary cells available in a wide variety of form factors. Battery packs can be designed to squeeze precisely into a portable electronic device right from the factory, and are available in standard and familiar cell formats such as AAA, AA, C, or D.
  Secondary cell chemistries — from the venerable lead-acid type to advanced thin film cells — are available in configurations ranging from uninterruptible power supply batteries for server farms filling entire rooms, to tiny thin-film batteries that can be embedded into integrated circuit packages to provide distributed storage on a much smaller scale.
评论(0)
发评论
下载排行榜
