Charge Pump vs. Ind. DC/DC Converter
Power conversion efficiency
over limit input voltage range
Lower quiescent current
Small board size and less external
component of total solution
Low cost of total solution
Load disconnect at Shout down
Ease of use
Low EMI
Low output voltage ripple
Low ESR ceramic capacitor needed
over wide input voltage range
High transformation ratio
(Rather large) inductor
Low EMI difficult to reach
