电流传感单通道驱动器IRS212(7, 71, 8,81)(S)PbF
消耗积分:0 | 格式:rar | 大小:1.53 MB | 2017-09-11
分享资料个
  The IRS2127/IRS2128/IRS21271/IRS21281 are high voltage, high speed power MOSFET and IGBT drivers. Proprietary HVIC and latch immune CMOS technologies enable ruggedized monolithic construction. The logic input is compatible with standard CMOS or LSTTL outputs, down to 3.3 V. The protection circuity detects over-current in the driven power transistor and terminates the gate drive voltage. An open drain FAULT signal is provided to indicate that an over-current shutdown has occurred. The output Product Summary VCC VB CS HO COM VS IN FAULT V CC IN FAULT VCC VB CS HO COM VS IN FAULT V CC IN FAULT (Referto LeadAssignmentsfor correct pin configuration)。 Thesediagrams show electrical connectionsonly. Please refer to our Application Notes and DesignTips for proper circuit board layout. driver features a high pulse current buffer stage designed for minimum cross-conduction. The floating channel can be used to drive an N-channel power MOSFET or IGBT in the high-side or low-side configuration which operates up to 600 V.
评论(0)
发评论
下载排行榜
