MAX7317 SPI借口IO口扩展IC
消耗积分:0 | 格式:rar | 大小:0.30 MB | 2017-09-18
分享资料个
  The MAX7317 serial-interfaced peripheral provides
  microprocessors with 10 I/O ports rated to 7V. Each
  port can be individually configured as either an opendrain output, or an overvoltage-protected Schmitt input.
  The MAX7317 supports hot insertion. All port pins
  remain high impedance in power-down (V+ = 0V) with
  up to 8V asserted on them.
  The MAX7317 is available in 16-pin thin QFN and QSOP
  packages and operates in the -40°C to +125°C range.
  For a similar part with constant-current outputs and 8-bit PWM controls, refer to the MAX6966/MAX6967
  data sheet.
评论(0)
发评论
下载排行榜
