The IL2901 consists of four independent precision voltage
comparators with an offset voltage specification as low as 2.0
mV max for four comparators which were designed
specifically to operate from a single power supply over a wide
range of voltages.
Application areas include limit comparators, simple analog
to digital converters; pulse, square wave and time delay
generators; wide range VCO; MOS clock timers;
multivibrators and high voltage digital logic gates.
