This document describes the UART & CAN bootloader functionality as well as the
serial protocols to efficiently perform operations on the on chip Flash & EEPROM
memories.
This bootloader implements the “In-System Programming” (ISP)。 The ISP allows the
user to program or re-program the microcontroller on-chip Flash & EEPROM memories without removing the device from the system and without the need of a preprogrammed application.
The CAN & UART bootloader can manage a communication with an host through a
serial network or serial line. It can also access and perform requested operations on
the on-chip Flash & EEPROM memories.
