Planar passivated chips ● Very low leakage current ● Very short recovery time ● Improved thermal behaviour ● Very low Irm-values ● Very soft recovery behaviour ● Avalanche voltage rated for reliable operation ● Soft reverse recovery for low EMI/RFI ● Low Irm reduces: - Power dissipation within the diode - Turn-on loss in the commutating switch
● Rectifiers in switch mode power supplies (SMPS)
Isolation Voltage: V~ Industry convenient outline ● RoHS compliant ● Epoxy meets UL 94V-0 ● Soldering pins for PCB mounting ● Backside: DCB ceramic ● Reduced weight ● Advanced power cycling
