AD7291,pdf datasheet (with Tem
消耗积分:5 | 格式:rar | 大小:223 | 2009-11-25
分享资料个
The AD7291 is a 12-bit, high speed, low power, 8-channel, successive approximation ADC with an internal temperature sensor. The part operates from a single 3.3V power supply and features an I2C®-compatible interface. The track-and-hold amplifier which can handle input frequencies of up to 70MHz, and a multiplexer allows samples from eight channels.
评论(0)
发评论
下载排行榜
