Development of a tilt measurement system based on MEMS sensor and Cortex_M3
消耗积分:0 | 格式:rar | 大小:0.46 MB | 2017-09-28
分享资料个
  Tilt measurement system is a device used to measure
  the tilt angle of the carrier to horizontal plane, which is
  widely used in attitude measurement fields such as
  MUAV, robot, motorcar, ship and so on. The
  accelerometer can be used for the tilt measurement
  because of its measurement principle. With the
  development of MEMS technology, the MEMS
  accelerometer becomes the best choice to design the
  micro tilt measurement system for its small size, low
  power, low cost and strong anti-impact force although its
  measurement accuracy is lower. Recently how to design
  the micro tilt measurement system with proper chips and
  how to deduce the measurement error are studied[1-4]。
  This paper designs a low-cost, small-size and
  fast-response tilt measurement system. The contribution
  of this work focuses on two aspects. One is sticking the
  3-axis MEMS accelerometer on some plane of a
  hexahedron and compensating for the accelerometer
  sensitivity drift with temperature by the sensor in the
  microcontroller, which makes calibration and error easier
  and less. The next is using a Cortex-M3 microcontroller to
  process data, which makes the power consumption and the
  performance of the system lower and higher.
  The remainder of this paper is organized as follows. In
  Section II we will briefly introduce the measuring
  principle and the structure of the tilt measurement system.
  In Section III we will describe the hardware design of the
  system. In Section Č we will show how to compensate
  the drift error of the accelerometer with the temperature.
  In Section č we will describe the algorithm realization of
  the system. In Section Ď experimental results are
评论(0)
发评论
下载排行榜
