AD532内部微调的集成电路乘法器数据表
消耗积分:0 | 格式:rar | 大小:0.40 MB | 2017-09-28
分享资料个
  The AD532 is the first pretrimmed, single chip, monolithic multiplier/divider. It guarantees a maximum multiplying error of ±1.0% and a ±10 V output voltage without the need for any external trimming resistors or output op amp. Because the AD532 is internally trimmed, its simplicity of use provides design engineers with an attractive alternative to modular multipliers, and its monolithic construction provides significant advantages in size, reliability, and economy. Further, the AD532 can be a direct replacement for other IC multipliers that require external trim networks.
评论(0)
发评论
下载排行榜
