Each operator has a precedence number assigned to it that determines the order in which
the operator and its operands are evaluated. The precedence numbers range from 1 (the
highest precedence, that is, first evaluated) to 7 (the lowest precedence, that is, last
evaluated)。
The following rules determine how expressions are evaluated:
● The highest precedence operators are evaluated first, then the second highest
precedence operators, and so on until the lowest precedence operators are evaluated.
● Operators of equal precedence are evaluated from left to right in the expression.
● Parentheses ( and ) can be used for grouping operators and operands and for
controlling the order in which the expressions are evaluated. For example, the
folloin exression ealuates to
