1.创建文件夹 //using System.IO; Directory.CreateDirectory(%%1); 2.创建文件 //using System.IO; File.Create(%%1); 3.删除文件 //using System.IO; File.Delete(%%1); 4.删除文件夹 //using System.IO; Directory.Delete(%%1); 5.删除一个目录下所有的文件夹 //using System.IO; foreach (string dirStr in Directory.GetDirectories(%%1)) { DirectoryInfo dir = new DirectoryInfo(dirStr); ArrayList folders=new ArrayList(); FileSystemInfo[] fileArr = dir.GetFileSystemInfos(); for (int i = 0; i 《 folders.Count; i++) { FileInfo f = folders[i] as FileInfo; if (f == null) { DirectoryInfo d = folders[i] as DirectoryInfo; d.Delete(); } } } 6.清空文件夹 //using System.IO; Directory.Delete(%%1,true); Directory.CreateDirectory(%%1); 7.读取文件 //using System.IO; StreamReader s = File.OpenText(%%1); string %%2 = null; while ((%%2 = s.ReadLine()) != null){ %%3 } s.Close();
