General Feature 8-Channel capacitive sensor with auto sensitivity calibration Selectable output operation (single or multi output mode) Low current consumption Uniformly adjustable 2 step sensitivity Sync function for parallel operation Adjustable internal frequency with external resister Selectable sense line impedance out of scanning Open-drain digital output Embedded common and normal noise elimination circuit RoHS compliant 24SOP and 32QFN package 1.2 Application Home application Membrane switch replacement Sealed control panels, keypads Door key-lock matrix application Touch screen replacement application
