OXuPCI952 Datasheet
Combining PLX\‘s high performance UART and universal voltage PCI technology, the OXuPCI952 is the ideal connectivity solution for a diverse range of products requiring low density port expansion including: PC Add-on Cards, Industrial PC, Point of Sale Terminals, Industrial Control and Network Management.
This highly integrated device is backed by certified device drivers, for a wide range of operating systems, to deliver ultimate performance with reduced design cycles and accelerated time to market.
The OXuPCI952 is a single chip, dual serial and single parallel port or local bus solution for universal PCI based serial and parallel connectivity applications. The device incorporates PLX\’s high performance, feature-rich UART technology that combines the industry\‘s fastest baud rates and deepest FIFOs with unrivalled flexibility. It adds up to a class leading serial connectivity solution.
