This document describes the ARM®-based 32-bit MCU STM32F101xx and STM32F103xx
firmware library.
This library is a firmware package which contains a collection of routines, data structures
and macros covering the features of all peripherals. It includes a description of the device
drivers plus a set of examples for each peripheral. The firmware library allows any device to
be used in the user application without the need for in-depth study of each peripheral
specifications. As a result, using the firmware library saves significant time that would
otherwise be spent in coding, while reducing the application development and integration
cost.
Each device driver consists of a set of functions covering all peripheral functionalities. The
development of each driver is driven by a common API (application programming interface)
which standardizes the driver structure, the functions and the names of parameters.
The driver source code is developed in ‘Strict ANSI-C’ (relaxed ANSI-C for projects and
examples files)。 It is fully documented and is MISRA-C 2004 compliant (the compliancy
matrix is available upon request)。 Writing the whole library in ‘Strict ANSI-C’ makes it
independent from the software toolchain. Only the start-up files depend on the toolcha
