an I2
C, two channels of UART, and
plenty of general-purpose I/O ports
(GPIO)。 There is a small OLED display
on the evaluation board. This 1″
bright yellowish panel is a fine-pitch
96 × 16 graphic display connected to
the LM3S811 through the I2
C interface. Unlike most LCDs, the OLED
display has a very fast response time,
which is ideal for displaying rapidly
changing oscilloscope
waveforms. A USB controller is also available on
the board for JTAG control
and serial port emulation.
The USB serial port emulation connection can be
used to deliver the captured waveform to a host
PC and show the waveform on a larger, higherresolution PC screen.
Finally, we developed a
small battery-powered
multifunction device with
the following functions: A
dual-channel oscilloscope
supports 250 ksps for each
channel. Each channel has
seven gain settings, which
allow the full-scale display
to be independently set to
±10 V, ±5 V, ±2 V, ±1 V, ±500
mV, ±200 mV, or ±100 mV.
The trigger method includes
Free-Running (Auto) modeastic box. The
e dual-channel
e other end.
This is the
he LM3S811
