When you invoke GCC, it normally does preprocessing, compilation, assembly and linkingThe “overall options” allow you to stop this process at an intermediate stage. For example,the ‘-c’ option says not to run the linker. Then the output consists of object files outputby the assembler.Other options are passed on to one stage of processing. Some options control the preprocessor and others the compiler itself. Yet other options control the assembler and linker;most of these are not documented here, since you rarely need to use any of them.Most of the command-line options that you can use with GCC are useful for C programs;when an option is only useful with another language (usually C++), the explanation saysso explicitly. If the description for a particular option does not mention a source language,you can use that option with all supported languages.See Section 3.3 [Compiling C++ Programs], page 29, for a summary of special options forcompiling C++ programs.The gcc program accepts options and file names as operands. Many options have multiletter names; therefore multiple single-letter options may not be grouped: ‘-dv’ is verydifferent from ‘-d -v’.You can mix options and other arguments. For the most part, the order you use doesn’tmatter. Order does matter when you use several options of the same kind; for example, if
you specify ‘-L’ more than once, the directories are searched in the order specified. Also,the placement of the ‘-l’ option is significant.Many options have long names starting with ‘-f’ or with ‘-W’—for example,‘-fmove-loop-invariants’, ‘-Wformat’ and so on. Most of these have both positive andnegative forms; the negative form of ‘-ffoo’ is ‘-fno-foo’。 This manual documents onlyone of these two forms, whichever one is not the default.See [Option Index], page 747, for an index to GCC’s option
