ADDI7004,pdf datasheet (with P
消耗积分:5 | 格式:rar | 大小:221 | 2009-12-07
分享资料个
The ADDI7004 is a highly integrated, quad-channel, HD image
signal processor for high speed imaging applications. Each channel
is specified at pixel rates of up to 72 MHz and consists of a complete
analog front end (AFE) with ADC conversion. The Precision
Timing™ core allows adjustment of the correlated double sampler
(CDS) and sample-and-hold amplifier (SHA) clocks with 220 ps
resolution at 72 MHz operation. The ADDI7004 also contains
a reduced range low voltage differential signaling (LVDS) interface
for the dual-channel data outputs.
评论(0)
发评论
下载排行榜
