This document describes the hexadecimal object file format for the Intel 8-bit, 16-bit, and 32-bit
microprocessors. The hexadecimal format is suitable as input to PROM programmers or hardware
emulators.
Hexadecimal object file format is a way of representing an absolute binary object file in ASCII. Because
the file is in ASCII instead of binary, it is possible to store the file is non-binary medium such as
paper-tape, punch cards, etc.; and the file can also be displayed on CRT terminals, line printers, etc.。 The
8-bit hexadecimal object file format allows for the placement of code and data within the 16-bit linear
address space of the Intel 8-bit processors. The 16-bit hexadecimal format allows for the 20-bit
segmented address space of the Intel 16-bit processors. And the 32-bit format allows for the 32-bit linear
address space of the Intel 32-bit processors.
The hexadecimal representation of binary is coded in ASCII alphanumeric characters. For example,
the 8-bit binary value 0011-1111 is 3F in hexadecimal. To code this in ASCII, one 8-bit byt
containing the ASCII code for the character ‘3’ (0011-0011 or 033H) and one 8-bit byte containing the
ASCII code for the character ‘F’ (0100-0110 or 046H) are required. For each byte value, the high-order
hexadecimal digit is always the first digit of the pair of hexadecimal digits. This representation (ASCII
hexadecimal) requires twice as many bytes as the binary representation.
