ISL54210 pdf datasheet
消耗积分:3 | 格式:rar | 大小:3333 | 2008-08-05
杨海清
分享资料个
The Intersil ISL54210 dual SPDT (Single Pole/Double Throw) switch combines low distortion audio and accurate USB 2.0 high speed data (480Mbps) signal switching in the same low voltage device. When operated with a 2.7V to 3.6V single supply, these analog switches allow audio signal swings below-ground, allowing the use of a common USB and audio headphone connector in Personal Media Players and other portable battery powered devices.
评论(0)
发评论
下载排行榜
