MM54HC354/MM74HC354/ MM54HC356/MM74HC356 8-Channel TRI-STATEÉ Multiplexers with Latches General Description The MM54HC354/MM74HC354 and MM54HC356/ MM74HC356 utilize advanced silicon-gate CMOS technology. They exhibit the high noise immunity and low power dissipation of standard CMOS integrated circuits, along with the ability to drive 15 LS-TTL loads. Due to the large output drive capability and the TRI-STATE feature, these devices are ideally suited for interfacing with bus lines in a bus organized system. These data selectors/multiplexers contain full on-chip binary decoding to select one of eight data sources. The data select address is stored in transparent latches that are enabled by a low level address on pin 11, SC. Data on the 8 input lines is stored in a parallel input/output register which in the MM54HC354/MM74HC354 is composed of 8 transparent latches enabled by a low level on pin 9, DC, and in the MM54HC356/MM74HC356 is composed of 8 edge-triggered flip-flops, clocked by a low to high transition on pin 9, CLK. Both true (Y) and complementary (W) TRI-STATE outputs are available on both devices. The 54HC/74HC logic family is functionally as well as pinout compatible with the standard 54LS/74LS-TTL logic family. All inputs are protected from damage due to static discharge by internal diode clamps to VCC and ground. Features Y Transparent latches on data select inputs Y Choice of data registers: Transparent ('354) Edge-triggered ('356) Y TRI-STATE complementary outputs with fanout of 15 LS-TTL loads Y Typical propagation delay: Data to output ('354): 32 ns Clock to output ('346): 35 ns Y Wide power supply range: 2V±6V Y Low quiescent supply current: 80 mA maximum Y Low input current: 1 mA maximum
