MM54HC540/MM74HC540 Inverting Octal TRI-STATEÉ Buffer MM54HC541/MM74HC541 Octal TRI-STATE Buffer General Description These TRI-STATE buffers utilize advanced silicon-gate CMOS technology. They possess high drive current outputs which enable high speed operation even when driving large bus capacitances. These circuits achieve speeds comparable to low power Schottky devices, while retaining the advantage of CMOS circuitry, i.e., high noise immunity, and low power consumption. Both devices have a fanout of 15 LS-TTL equivalent inputs. The MM54HC540/MM74HC540 is an inverting buffer and the MM54HC541/MM74HC541 is a non-inverting buffer. The TRI-STATE control gate operates as a two-input NOR such that if either G1 or G2 are high, all eight outputs are in the high-impedance state. In order to enhance PC board layout, the 'HC540 and 'HC541 offers a pinout having inputs and outputs on opposite sides of the package. All inputs are protected from damage due to static discharge by diodes to VCC and ground. Features Y Typical propagation delay: 12 ns Y TRI-STATE outputs for connection to system buses Y Wide power supply range: 2±6V Y Low quiescent current: 80 mA maximum (74HC Series) Y Output current: 6 mA
