74LS03 pdf datasheet
消耗积分:3 | 格式:rar | 大小:133 | 2008-08-06
分享资料个
54LS03/DM54LS03/DM74LS03
Quad 2-Input NAND Gates
with Open-Collector Outputs
General Description
This device contains four independent gates each of which
performs the logic NAND function. The open-collector outputs
require external pull-up resistors for proper logical operation.
Features
Y Alternate Military/Aerospace device (54LS03) is available.
Contact a National Semiconductor Sales Office/
Distributor for specifications.
Pull-Up Resistor Equations
RMAX e
VCC (Min) b VOH
N1 (IOH) a N2 (IIH)
RMIN e
VCC (Max) b VOL
IOL b N3 (IIL)
Where: N1 (IOH) e total maximum output high current for all
outputs tied to pull-up resistor
N2 (IIH) e total maximum input high current for all
inputs tied to pull-up resistor
N3 (IIL) e total maximum input low current for all
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
