54LS256/DM74LS256 Dual 4-Bit Addressable Latch General Description The 'LS256 is a dual 4-bit addressable latch with common control inputs; these include two Address inputs (A0, A1), an active LOW enable input (E) and an active LOW Clear input (CL). Each latch has a Data input (D) and four outputs (Q0±Q3). When the Enable (E) is HIGH and the Clear input (CL) is LOW, all outputs (Q0±Q3) are LOW. Dual 4-channel demultiplexing occurs when the CL and E are both LOW. When CL is HIGH and E is LOW, the selected output (Q0±Q3), determined by the Address inputs, follows D. When the E goes HIGH, the contents of the latch are stored. When operating in the addressable latch mode (E e LOW, CL e HIGH), changing more than one bit of the Address (A0, A1) could impose a transient wrong address. Therefore, this should be done only while in the memory mode (E e CL e HIGH). Features Y Serial-to-parallel capability Y Output from each storage bit available Y Random (addressable) data entry Y Easily expandable Y Active low common clear
