74LS352/54LS352 pdf datasheet
消耗积分:2 | 格式:rar | 大小:333 | 2008-08-06
分享资料个
54LS352/DM74LS352 Dual 4-Line to
1-Line Data Selectors/Multiplexers
General Description
Each of these data selectors/multiplexers contains inverters
and drivers to supply fully complementary, on-chip, binary
decoding data selection to the AND-OR-invert gates.
Separate strobe inputs are provided for each of the two
four-line sections.
Features
Y Inverting version of DM54/74LS153
Y Permits multiplexing from N lines to 1 line
Y Performs parallel-to-serial conversion
Y Strobe (enable) line provided for cascading (N lines to
n lines)
Y High fan-out, low-impedance, totem-pole outputs
Y Typical average propagation delay times
From data 15 ns
From strobe 19 ns
From select 22 ns
Y Typical power dissipation 31 mW
评论(0)
发评论
下载排行榜
