Hamilton计时说明书
消耗积分:2 | 格式:rar | 大小:2046 | 2010-01-20
48674
分享资料个
Hamilton计时说明书.pdf
Adjustments
NB: On certain models the crown is screwed down
to guarantee optimal water-resistance. It must be
unscrewed to make adjustments. After adjustments
make sure it is screwed down again.
Please note that water-resistance is only guaranteed
when the crown is screwed down.
Setting the time
(. Pull out the crown 􀀙 completely to position (p$):
the seconds hand stops*.
$. Set the time by turning the crown in the desired
direction.
). Push the crown back in completely: the
seconds hand starts again, allowing perfect
synchronization with a time signal.
* stop seconds according to model
评论(0)
发评论
下载排行榜
