Hamilton蛙人说明书.
消耗积分:2 | 格式:rar | 大小:1056 | 2010-01-20
分享资料个
Hamilton蛙人说明书.pdf
Hamilton is delighted that you have chosen a timepiece from its collection. You have acquired a small
technological marvel that will serve you faithfully for many years. The most advanced technologies were
used throughout its manufacture and it underwent stringent controls before it was released for sale.
Recommendations
Like all micro-mechanical precision instruments, your Hamilton watch should be checked at least once every two
years. Entrust your watch only to an authorized Hamilton agent. To keep your watch water-resistant, make sure
that its sealing features are tested at every check-up.
The water-resistance of your watch is 20 ATM = 200 meters = 660 feet.
Five basic rules for maintaining the water-resistance of your watch
1. Have your watch checked regularly.
2. Do not move the crown when you are in water.
3. Rinse off your watch after immersion in water.
4. Dry your watch whenever it gets wet.
5. Have your watch checked for water-resistance by an authorized
Hamilton agent each time the case is opened.
Your watch is fitted with an automatic movement. The mechanism of the watch includes an oscillating rotor that
winds the mainspring via the motion of your wrist. The running reserve is approximately 42 hours. If necessary,
the watch may be rewound manually. The beauty of the inner working of the watch movement can be admired
through the transparent case back.
评论(0)
发评论
下载排行榜
