AAT1150,pdf datasheet(1MHz 1A
消耗积分:5 | 格式:rar | 大小:221 | 2010-01-29
分享资料个
The AAT1150 SwitchReg™ is a step-down switching converter ideal for applications where high efficiency, small size, and low ripple are critical. Able to deliver 1A with internal power MOSFETs, the current-mode controlled IC provides high efficiency using synchronous rectification. Fully internally compensated, the AAT1150 simplifies system design and lowers external parts count.
评论(0)
发评论
下载排行榜
