AAT3221/AAT3222,pdf datasheet(
消耗积分:5 | 格式:rar | 大小:221 | 2010-01-30
赵辉
分享资料个
The AAT3221 and AAT3222 PowerLinear NanoPower low dropout (LDO) linear regulators are ideal for portable applications where extended battery life is critical. These devices feature extremely low quiescent current, typically 1.1μA. Dropout voltage is also very low, typically
less than 200mV at the maximum output current of 150mA. The AAT3221/2 have an enable pin feature which, when asserted, will enter the LDO regulator into shutdown mode, removing power from its load and offering extended power conservation capabilities for portable
battery-powered applications.
评论(0)
发评论
下载排行榜
