模拟退火算法的matlab示例:function s = simulatedannealing(inputcities,initial_temperature,... cooling_rate,threshold,numberofcitiestoswap) % SIMULATEDANNEALING % S = SIMULATEDANNEALING(inputcities,initial_temperature,cooling_rate) % returns the new configuration of cities with an optimal solution for the % traveling salesman problem for n cities. % %The input arguments are % INPUTCITIES - The cordinates for n cities are represented as 2 % rows and n columns and is passed as an argument for % SIMULATEDANNEALING. % INITIAL_TEMPERATURE - The initial temperature to start the % simulatedannealing process. % COOLING_RATE - Cooling rate for the simulatedannealing process. % Cooling rate should always be less than one. % THRESHOLD - Threshold is the stopping criteria and it is the % acceptable distance for n cities. % NUMBEROFCITIESTOSWAP- Specify the maximum number of pair of cities to % swap. As temperature decreases the number of cities % to be swapped decreases and eventually reaches one % pair of cities.
