MAX13170E pdf datasheet (多协议收发
消耗积分:3 | 格式:rar | 大小:999 | 2008-08-10
分享资料个
The MAX13170E is a three-driver/three-receiver multiprotocol
transceiver that operates from a +5V single supply.
The MAX13170E, along with the MAX13172E and the
MAX13174E, form a complete software-selectable data
terminal equipment (DTE) or data communication equipment
(DCE) interface port that supports the V.28 (RS-232),
V.10/V.11 (RS-449/V.36, EIA-530, EIA-530A, X.21), and
V.35 protocols. The MAX13170E transceivers carry the
high-speed clock and data signals, while the MAX13172E
carry the control signals. The MAX13170E can be terminated
by the MAX13174E software-selectable resistor
termination network or by discrete termination networks.
The MAX13170E has an internal charge pump and a
proprietary low-dropout transmitter output stage that
allows V.11-, V.28-, and V.35-compliant operation from
a +5V single supply. The MAX13170E features a nocable
mode that reduces supply current to 0.5μA, and
disables all (high-impedance) transmitter and receiver
outputs. Short-circuit current limiting and thermal shutdown
circuitry protect the receiver and transmitter outputs
against excessive power dissipation. The
MAX13170E has extended ESD protection for all the
transmitter outputs and receivers inputs.
The MAX13170E is available in a 5.3mm x 10.2mm,
28-pin SSOP package and operates over the 0°C to
+70°C commercial temperature range.
评论(0)
发评论
下载排行榜
