采用DSP TMS320F2812的永磁同步电机直接转矩控制
消耗积分:5 | 格式:rar | 大小:554 | 2010-02-26
goodmbby
分享资料个
摘要:文章根据永磁同步电机的数学模型和直接转矩控制的基本原理,设计了一种基于TMS320F2812的全数字化直接转矩控制系统。首先利用MATLAB软件对直接转矩控制系统进行建模和仿真,得到电流、转速、转矩以及磁链的仿真波形,然后对系统进行实验研究。
According to the mathematicalmodel of PermanentMagnet SynchronousMotor and p rincip le of Di2rect Torque Control System, a DigitalDTC control system based on DSP TMS320F2812 is p roposed in this pa2per. Firstly, the modeling and simulation of the control system are introduced based onMATLAB /SIMUL INK. It is showed that the system was designed rightly. Then the control system can be experimented.
评论(0)
发评论
下载排行榜
