UL 1012 Power Units Other Than
消耗积分:3 | 格式:rar | 大小:333 | 2010-03-01
刘杰
分享资料个
A. This Standard contains basic requirements for products covered by Underwriters Laboratories Inc. (UL) under its Follow-Up Service for this category within the limitations given below and in the Scope section of this Standard. These requirements are based upon sound engineering principles, research, records of tests and field experience, and an appreciation of the problems of manufacture, installation, and use derived from consultation with and information obtained from manufacturers, users, inspection authorities,and others having specialized experience. They are subject to revision as further experience and investigation may show is necessary or desirable.
评论(0)
发评论
下载排行榜
