LPC2131/2132/2134/2136/2138 datasheet,pdf
Single-chip 16/32-bit microcontrollers; 32/64/128/256/512 kB ISP/IAP Flash with 10-bit ADC and DAC
The LPC2131/2132/2134/2136/2138 microcontrollers are based on a 32/16 bit
ARM7TDMI-S CPU with real-time emulation and embedded trace support, that combines
the microcontroller with 32 kB, 64 kB, 128 kB, 256 kB and 512 kB of embedded high
speed Flash memory. A 128-bit wide memory interface and a unique accelerator
architecture enable 32-bit code execution at maximum clock rate. For critical code size
applications, the alternative 16-bit Thumb mode reduces code by more than 30 % with
minimal performance penalty.
