Applications
• BC0 notch filter for SVLTE applications
• Applicable passbands: 751 MHz B13 LTE, 782 MHz B13 LTE
• Handsets
General Description Pin Configuration
The 857031 is a high performance Surface Acoustic Wave (SAW) Notch Filter designed to reject emissions in the BC0 band while passing Band 13 LTE band.
857031 is specifically designed to enable simultaneous voice and LTE for Band 13 application. It is specified to support Band 13 requirements in the entire 746 - 787 MHz band. The 857031 uses advanced packaging techniques to achieve an industry-leading 2.5 x 2.0 x 0.56 mm package.
The filter exhibits excellent power handling capabilities.
