Applications
• Wireless Infrastructure
• LTE / WCDMA / CDMA / EDGE
• PtP IF Gain Control • General Purpose Wireless
Product Features
• Integrates Amp + VVA + Amp functionality
• 500−2700 MHz Bandwidth
• 38 dB Gain (max gain setting)
• 4.0 dB Noise Figure • +16 dBm P1dB
• +29 dBm OIP3
• +5V Supply Voltage
• Low Current
General Description
The TQM8M9079 is an analog controlled variable gain amplifier (VGA) which operates from 500 to 2700 MHz. The VGA is able to provide broadband performance with +29 dBm OIP3 and +16 dBm P1dB over a wide frequency range while only consuming 95 mA current.
The TQM8M9079 integrates two broadband gain blocks with a voltage variable attenuator. The three stages are individually accessible via package I/O contacts. This permits full flexibility to insert other components or filters between the stages.
The TQM8M9079 is packaged in a RoHS-compliant, compact 5x5 mm surface-mount leadless package. Superior thermal design allows the product to have a minimum MTTF rating of 1000 years at a mounting temperature of +85° C.
The TQM8M9079 is targeted for use in wireless infrastructure, IF gain control in point-to-point applications, and for general purpose wireless.
