MAX8934A, MAX8934B, MAX8934C,
消耗积分:5 | 格式:rar | 大小:233 | 2010-03-28
分享资料个
The MAX8934_ dual-input Li+/Li-Poly linear battery chargers
with Smart Power SelectorK safely charge a single
Li+/Li-Poly cell in accordance with JEITA recommendations.
The MAX8934_ monitors the battery temperature
(TBATT) while charging, and automatically adjusts the
fast-charge current and charge termination voltage as the
battery temperature varies. The MAX8934_ also monitors
the battery temperature while the battery is discharging,
and provides a warning flag (OT) to the system in the
event that the battery is over temperature. Two safety
profiles are supported (see the Charging Profiles section
for details). An ultra-low IQ, always-on LDO provides an
additional 3.3V supply for system power.
评论(0)
发评论
下载排行榜
