MPLAB C30用户指南(英文)
消耗积分:10 | 格式:rar | 大小:2867 | 2010-04-24
分享资料个
MPLAB C30用户指南(英文)
HIGHLIGHTS
The information covered in this chapter is as follows:
• About this Guide
• Recommended Reading
• Troubleshooting
• The Microchip Web Site
• Development Systems Customer Notification Service
• Customer Support
Document Layout
The document layout is as follows:
• Chapter 1: Compiler Overview – describes MPLAB C30, development tools and
feature set.
• Chapter 2: Differences between MPLAB C30 and ANSI C – describes the
differences between the C language supported by MPLAB C30 syntax and the
standard ANSI-89 C.
• Chapter 3: Using MPLAB C30 – describes how to use the MPLAB C30 compiler
from the command line.
• Chapter 4: MPLAB C30 Runtime Environment – describes the MPLAB C30
runtime model, including information on sections, initialization, memory models, the
software stack and much more.
• Chapter 5: Data Types – describes MPLAB C30 integer, floating point and pointer
data types.
• Chapter 6: Device Support Files – describes the MPLAB C30 header and register
definition files, as well as how to use with SFR’s.
• Chapter 7: Interrupts – describes how to use interrupts.
• Chapter 8: Mixing Assembly Language and C Modules – provides guidelines to
using MPLAB C30 with MPLAB ASM30 assembly language modules.
评论(0)
发评论
下载排行榜
