MLV Series Low Voltage Pressur
消耗积分:3 | 格式:rar | 大小:1126 | 2010-05-14
84784
分享资料个
MLV Series Low Voltage Pressure Sensors
The MLV Series Compensated Sensor is based on All Sensors’ CoBeam2 TM Technology. The device provides a high output signal at a low operating voltage while maintaining comparable output levels to traditional equivalent compensated millivolt sensors operating at higher voltages. This lower supply voltage gives rise to improved warm-up shift while the CoBeam2 Technology itself reduces package stress susceptibility resulting in improved overall long term stability. The technology also vastly improves position sensitivity compared to conventional single die devices.
评论(0)
发评论
下载排行榜
