Interfacing the TMS320C54x DSP
消耗积分:2 | 格式:rar | 大小:106 | 2010-06-23
凤毛麟角
分享资料个
ABSTRACT
This application report presents a method for interfacing the TLC320AD535 and
TLC320AD545 codecs from Texas Instruments (TIE) with the multichannel buffered serial
port (McBSP) on TI’s C54xx family of digital signal processors (DSPs). As is the case with
many codecs from TI, these devices utilize a primary and secondary communication protocol
to differentiate between actual signal data and codec control register data. This
communication protocol is discussed, and example C-language code for the DSP is provided
that initializes both the McBSP and the codec and then performs a simple codec echo
function. A description of the code and code flow is given. Finally, there is a brief discussion
on applying this work to other TI codecs.
评论(0)
发评论
下载排行榜
