lt1468 pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-09-01
laisvl
分享资料个
The LT®1468-2 is a precision high speed operational amplifi
er with 16-bit accuracy, decompensated to be stable in a
gain of 2 or greater. The combination of precision and AC
performance makes the LT1468-2 the optimum choice for
high accuracy applications such as DAC current-to-voltage
conversion and ADC buffers. The initial accuracy and drift
characteristics of the input offset voltage and inverting input
bias current are tailored for inverting applications.
The 200MHz gain bandwidth ensures high open-loop gain
at frequency for reducing distortion. In noninverting applications
such as an ADC buffer, the low distortion and
DC accuracy allow full 16-bit AC and DC performance.
The high slew rate of the LT1468-2 improves large-signal
performance in applications such as active fi lters and
instrumentation amplifi ers compared to other precision
op amps.
The LT1468-2 is specifi ed on power supply voltages of
±5V and ±15V and from –40°C to 85°C. For a unity-gain
stable op amp with same DC performance, see the LT1468
datasheet.
评论(0)
发评论
下载排行榜
