CC2420 Errata Notes
消耗积分:2 | 格式:rar | 大小:252 | 2010-07-02
吴湛
分享资料个
Active and passive scans as defined in IEEE 802.15.4 are affected by a bug in
the CC2420 hardware address recognition causing beacon frames to be
rejected. The bug can be avoided in software and is also fixed in the latest
hardware revision.
Description and reason for the problem
Early revisions of the CC2420 hardware address recognition contains a bug, which
causes beacon frames to be rejected even if the PAN ID programmed into CC2420
RAM is equal to 0xFFFF. This affects active and passive scans as defined by IEEE
802.15.4.
评论(0)
发评论
下载排行榜
