Switching between certain combinations of frequency words (FREQ) in CC1050
may cause the PLL never to be able to lock. This is most likely to occur in
frequency hopping systems. A software fix solves the problem.
Description and reason for the problem
When a new frequency is selected by updating the FREQ registers or changing the
MAIN.F_REG bit, a non-valid value can be latched due to internal clock skew. This
non-valid value may put the PLL in a deadlock situation and prevent the PLL from
locking.
The deadlock situation can happen if the 3 most significant bits of the FREQ words
are different for the two frequencies. If the 3 most significant bits are equal, the
deadlock will not occur. To ensure that the most significant bits are equal, use the
same reference frequency divider value (REFDIV) for all channels.
