Ten Things to Consider When Se
消耗积分:2 | 格式:rar | 大小:634 | 2010-07-22
李伟
分享资料个
Introduction
You rely on your oscilloscope
every day, so selecting the right
one to meet your needs is an
important task. Comparing the
specs and features of scopes
made by different manufacturers
can be time-consuming and
confusing. The concepts outlined
in this article are intended to
speed your selection process and
help you avoid some common
pitfalls. No matter who makes the
scopes you are considering,
carefully analyzing each
one in relation to the ten
issues discussed herein
will help you evaluate
the instruments
objectively.
评论(0)
发评论
下载排行榜
