CY74FCT162841CT,pdf(20-Bit Lat
消耗积分:3 | 格式:rar | 大小:504 | 2010-07-30
哈哈哈
分享资料个
The CY74FCT16841T and CY74FCT162841T are 20-bit D-type latches designed for use in bus applications requiring high speed and low power. These devices can be used as two independent 10-bit latches, or as a single 10-bit latch, or as a single 20-bit latch by connecting the Output Enable (OE\) and Latch (LE) inputs. Flow-through pinout and small shrink packaging aid in simplifying board layout.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
The CY74FCT16841T is ideally suited for driving high-capacitance loads and low-impedance backplanes.
The CY74FCT162841T has 24-mA balanced output drivers with current limiting resistors in the outputs.
评论(0)
发评论
下载排行榜
