OPC Client Checklist v2.0C
消耗积分:3 | 格式:rar | 大小:198 | 2010-08-11
分享资料个
Considerations:
The OPC Server you will be communicating with must be compliant with the 1.0 standard as a
minimum. Support for the 2.0 Standard is available with 4.01 SP10 to the latest versions.
Before you begin:
1.  Make sure you have properly installed and tested your OPC Server to verify that you do in
fact have a functioning system and it works as intended.
2.  Read and review the manuals (GFK-1675 – Section 4-13) / Help Files (Open Interface-
>Cimplicity OPC Server->Using the Cimplicity HMI OPC Server User Interface->Cimplicity
HMI OPC Server and DCOM) for the recommended OPC Server and Client DCOM*
1
 settings.
Although part of this manual is designed around the Cimplicity HMI OPC Server, it should still
be applicable to most other vendor‟s OPC Servers. DCOM plays a large part in proper
communication between an OPC Client and Server. If these settings are incorrect you may
not be able to properly establish communications.
评论(0)
发评论
下载排行榜
